904 thrust washers
JKCuda
Mechanicsburg, PA
Anyone know if you can still get these? Plan was to rebuild the 904 I have to mate to a 360 SB, I started to trans tear down today. Brass thrust washer that is between the input and output shaft is TOAST, half of it was missing. Can you still source this anywhere? All of the thrust washer kits I've found so far are steel which makes me a little hesitant. Part of me is wishing I would've just bought a 727 and dealt with having to cut or get a new driveshaft.
I have a store about 15 miles away, so I call and pick up.
Ah, ok. I'm nowhere near there. I've found a couple of thrust washer kits but they all look to be steel which worries me a little bit since the one I took out is brass.
