engine mount bracket
dougs grand cou
lafayette in
im replacing a 318 small block la engine with an ATK 408 cu in magnum engine and my old engine mount brackets are not exactly usable. is there anything on the market that will
Xcudame
Southeast Arizona
The easiest way is to check out Shumacher's.
Products
There should be ears on the Magnum motor like your 318. The passenger side is the same. It's the driver's side that's a little different. 340/360s used a different driver's side mount.
Xcudame
Southeast Arizona
By the way, you should introduce yourself and post photos of your grand coupe on the Welcome Wagon forum.
The passenger side bracket will work as is. The 318 driver’s side is 1/2 or 7/16 inch wider than the 360 Magnum mount but can be used with a spacer, or a couple of washers, etc.
