Juan Veldez
What kind of lube/sealer should I use at the rubber gasket where the fuel filler tube inserts into the gas tank?
Thanks. I had a question about the actual install also, but found your response in a previous thread.None, I usually just put some Vaseline on the inside of the rubber to help the tube slide in but it doesn't need any other sealer.
I understand and agree. But the funny thing is, it's the fuel tank and guess what is inside, petroleum. I will only use non ethanol gas in this thing. I hear ethanol gas is the number one cause of fires with all the rubber, and using a carburetor instead of fuel injection.Juan,
This is based on many years in the rubber industry(tires, related)
Generally you must be careful when using a petroleum based product with rubber parts. Silicone is the stuff to use. Or vegetable based. Same stuff used for tire mounting.,
Vaseline and rubber - Yahoo Search Results
search.yahoo.com
