Oystercopy
- Joined
- Jul 25, 2019
- Messages
- 111
- Reaction score
- 33
Hey guys.. several years ago, I upgraded the cam with a Comp Cam kit, for slightly better performance on the 440. I believe the lift was .477, so not super radical. However, since adding the cam, I've had a runnability problem, where the engine will not rev above about 3000rpm and bogs on acceleration. A couple of years ago, I also added a new Holley Fuel Pump, since the OEM one died on me, which did not change the bogging issue. So, at least I believe the carb is getting a good supply of fuel. Also replaced the carb with a brand new Edelbrock 750 and only ever ran non-Ethanol gas in the car. So, my question is, did I need to possibly add a higher output pump to the engine when I upgraded the cam? The bogging seems like its not getting enough fuel? If I get a fuel gauge and test it, my understanding is that it should have about 5-6psi in pressure. Lets assume that's the case, is that enough for a cammed engine and could it be I'm simply not getting enough fuel to the carb? Any help greatly appreciated!
OC
OC
