i have all my wiring done for the mad electrical to eliminate amp gauge. one question, the wires that go to the starter relay, do they go on the battery terminal or the wire that goes to starter?
battery.... if you look at all those wires they're connected to the plus terminal on the battery... if you connect them to the S terminal on the relay that will send constant 12v to the solenoid and the starter will spin all the time.
I know very little about electrical. I just installed a dash reverse indicator light. Was told to connect the wire to the backup light switch wire harness pigtail, which I did. The problem is that the indicator light comes on when I turn on the headlights, whether or not the car is in reverse??? Any help would be appreciated. Thanks, Sergio
