Mopar Parts Lots - E-body & Big Block
Claudia
Ohio
Specific pictures available upon request.
Both new and used parts.
Mopar BB / 727 Kick Down Linkage - 100
Mopar BB Misc Hardware – 25
Mopar BB Coil Mounting Bracket - 10
Mopar BB Coil Relocation Plate – 15
Mopar BB Cylinder Head Springs, Retainers & Exhaust Valves Set – 75
Mopar BB Chrome Valve Cover Hold Downs – 20
Mopar BB Valve Cover Gasket Set (rubber) - 25
Mopar BB Valve Cover Gasket Set (cork) - 10
Radiator Cap – 5
Mopar BB Timing Chain Cover – 50
Mopar BB Water Pump Gasket - 5
Mopar BB Camshaft - 50
Mopar BB Fan Clutch - 20
Mopar BB Fuel Pump Pushrod - 10
Mopar BB HP Exhaust Manifold Heat Riser - 125
66 - 72 B-body / 66 - 73 C-body / 70 - 74 E-body LH 440 Engine Support Bracket – 25
Mopar BB Fuel Pump Gaskets - 5
Mopar BB Flexplate – 30
Mopar BB Rear Main Seal Retainer - 30
Mopar BB Oil Pump Shaft - 30
Mopar BB Oil Pump – 40
Fram Oil Filter - 5
Mopar BB Oil Pickup Tube – 20 new
Mopar BB Oil Pickup Tube – 10 used
B / E-body Headlight Buckets (2) – 50
70 – 74 Challenger Fender to Core Support Braces - 30
Mopar Front Shock Mounting Hardware Kit – 10
71 - 74 E-body / 71 - 73 B-body Steering Column Seal Retainer - 20
Mopar Fuel Line Hardware Kit (3/8” supply – ¼” return) - 15
67 – 72 A-body / 66 - 70 B-body Starter Splash Shield – 45
Mopar Universal Power Brake Booster Mounting Brackets – 40
71-74 B / E-body Manual Master Cylinder Mounting Plate - 40
70-71 E-body Wiper Linkage Pivot – 45
70-74 E-body Front Windshield Driver Side Lower Corner Trim Molding - 30
Floor Heat Shield (approximately 6’ x 4’) - 40
70-74 E-body Standard Dash Light Bar - 50
70-74 Barracuda Weather Strip Channel Retainer Trim Set - 80
73-74 B-body Outside Mirror Gasket - 8
70 – 74 E-body Ignition Switch (missing connector) - 20
70 – 74 E-body Key Buzzer Switch (missing terminal ends) - 20
70 – 71 E-body Ignition Key Lock - 25
70 – 74 E-body Turn Signal Switch (missing connector) - 25
Mopar Late 60’s Interior Door Handles LH – 10 for both
Mopar Dome Light Assembly – 40
Vinyl Decal Application Spray and Gel – 10
70 – 74 Dodge Challenger Back Glass - 175
Holley Blue Electric Fuel Pump – 100
66-74 Mopar Trunk Latch Striker Plate - 20
68-74 B / E-body Trunk Lid Latch Striker - 25
62-74 B / E-body Trunk Lid Latch – 30
70-74 Barracuda License Plate Light Lens – 8 each
70-74 Plymouth Barracuda Fuel Tank Filler Neck Tube – 45
70-72 Challenger Rear Bumper Guard Bracket Set - 30
71 Barracuda Chrome Grill Taillight Bezel Set- 60
cudascott
I need all hardware for 70 RT challenger for hood latch, doors,and trunk lat he's and plates and bolts for all of them .radiator last 3 num956. Air cleaner, valve covers for 70 440 RT challenger 4 speed car. 3 speaker dash pad. Dog dish all 4.
Claudia
Ohio
I have an e-body trunk latch and a trunk latch striker with mounting hardware if you are interested.
