phenolic separators holley carburetors
Dana60
Phenolic separators for a Holley carb sixpac. Anybody know where I can get them??
burntorange70
Moderator
Aguanga,CA
Welcome to the site. Good to have you here. I would think that three two barrel adapters should do the trick. But don't realy know.
Summit has one for a Holly 2 bbl part number SUM-G1406
I don't know if that will work or not. But some one here with a six pack may know.
djwhog
Did that years ago, I was able back then to get them at the super shops performance store.
That is a good thing to do to rid some of the heat soak. I recall I had to add longer studs and just do a slight tweak of the throttle cable too. This was on a 4 speed Challenger. I went to school with this guy back i nthe day and he was the 1st owner. We saw about 8hp at the tires improvement when the engine was hot. Also seemed to help stop issues with heat perculation as well.
I added one to my 340 Cuda 4 v carter recently too.
Mopar Six-Packs use three Holley 2300 carbs
http://www.holley.com/17-72.asp
You may find better prices I think?
http://www.summitracing.com/parts/HLY-17-72/
