Spring loaded hood wedges
Tom's EK2
Harlan, Indiana
Asking if the AAR fiberglass hoods used the spring loaded alignment wedges located on the front fenders. Thanks again
Yes, the AAR 'Cuda used the fender to hood wedges. Chrysler number 2849228.
Thanks.
Appears they are different from steel hood alignment wedges or i got a poorly reproduced part. The set i have, the mounting holes for the small Phillips head screws do not "line up". not close at all.
Thanks.
The same wedge was used on all E-bodies and all hoods, steel and fiberglass. They were also the same on C-bodies in 1970, and started on the B-bodies as well in 1971 when the fender attachment changed from the earlier vertical mount to the horizontal mount style as used on the E-bodies. The misalignment may be a reproduction part issue, or fender issue if you have aftermarket/reproduction fenders. Used originals can take a little tweaking to get in place at times too.
Very good. Thanks-Tom
