STR12
AUSTA
PERTH WA
One is for sale locally is Australia quite rare also very expensive he is asking $3900 Aus
STR intake
New laser cut top plate gaskets x 3
O ringed thermostat housing
Mr Gasket 180 deg thermostat
New temp sender
Matched 450dp Holley Carbs with rear metering blocks
Billet linkages with 1-1 set up
-6 fuel lines and Earls fittings
Extreme K&N air filters
Also comes with correct Edelbrock fuel lines
This is a tunnel ram that fits under the bonnet and as you can see it's in extremely good condition.
I used to run one with the 6 pack set up. I traded it with 3 tops for a 68 Satellite Convertible. If I had it today, I would go fuel injection with it and solve the low RPM issues.
Did yours puddle fuel at idle?
Its not mine its for sale on site site called Mopar Parts
I tried a ezi -efi on a Offy Dual quad stroked 340 when its was good it run great but seems to need continual re tuning fitted a Fitech runs great although i run a quick fuel on my other 340 its 1 of those carbies that just run right from day 1 although needs a longer warmup than the Fitech
