STR12
AUSTA
PERTH WA
One is for sale locally is Australia quite rare also very expensive he is asking $3900 Aus
STR intake
New laser cut top plate gaskets x 3
O ringed thermostat housing
Mr Gasket 180 deg thermostat
New temp sender
Matched 450dp Holley Carbs with rear metering blocks
Billet linkages with 1-1 set up
-6 fuel lines and Earls fittings
Extreme K&N air filters
Also comes with correct Edelbrock fuel lines
This is a tunnel ram that fits under the bonnet and as you can see it's in extremely good condition.
challenger6pak
I used to run one with the 6 pack set up. I traded it with 3 tops for a 68 Satellite Convertible. If I had it today, I would go fuel injection with it and solve the low RPM issues.
AUSTA
PERTH WA
Did yours puddle fuel at idle?
Its not mine its for sale on site site called Mopar Parts
I tried a ezi -efi on a Offy Dual quad stroked 340 when its was good it run great but seems to need continual re tuning fitted a Fitech runs great although i run a quick fuel on my other 340 its 1 of those carbies that just run right from day 1 although needs a longer warmup than the Fitech
