windshield
BeauBonyx
LaFayette, LA
I need advise on fixing a leak on my windshield. It looks to be leaking on the passenger side behind the visor. If I get caught in the rain it drips.
I guess all you can do is remove the trim inside and out to see if you can pinpoint where it's coming in and then go to town with some sort of sealer.
Hopefully it's not due to a rust hole. Be very careful when removing the stainless trim, you must use the proper removal tool and it's possible that you're not the first person to deal with the leak on this car. Let's hope someone hasn't already gone to town with some sort of sealer on it because the trim could be a ***** to remove when it's glued down with silicone or whatever.
do you want to do it the right way.
the only safe way to get it out without braking it is to use piano wire and you will need a helper.
fix the rust on the pinch weld ,if there's any.
ready to reinstall.
