Latest activity
  • heminut
    heminut reacted to 1moretoy's post in the thread Master Cylinder mounting with
    Like
    Like
    Thanks for the offer Heminut, I actually found my plated today, woohoo. Thanks Xcudame, I purchased an adapter plate similar to the...
  • 6PKRTSE
    6PKRTSE replied to the thread Power Window Relay.
    Good to know I suppose. Both my 70 R/T S.E. Challenger and my 70 Charger R/T S.E. have power windows and I can honestly say that I have...
  • V
    I’m installing a 518 46rh in my 70 Challenger. My question is, “what is the new length of the speedometer cable”? Thanks for any...
  • C
    Chryco Psycho replied to the thread Any height difference?.
    600 cfm carb or 1000 cfm carb with 73 intake
  • J
    JMB711 replied to the thread Any height difference?.
    Why the 73? I'd think the 70 would be a better match with the 1970 X heads?
  • L
    larry4406 reacted to Surfcuda's post in the thread Power Window Relay with
    Like
    Like
    I came across this which gives a great overall diagram showing Relays attached to the Fuse Box. I have Relays “A” and “B” but definitely...
  • 383RT
    383RT reacted to O5C's post in the thread what is the best paint for a 1970 hemi engine? with
    Like
    Like
    If you are striving for an accurate restoration, I suggest product number HEPPL (70-71 Hemi engi engine paint) procured from Roger...
  • L
    larry4406 reacted to Slotts's post in the thread Power Window Relay with
    Like
    Like
    The 2926433 power window relay clip mounts on the lower right side of the fuse block. Jim
  • S
    Surfcuda replied to the thread Power Window Relay.
  • C
    The intakes are very similar other than the different carb mounting , personally if you have a good TQ I would use that & the 73 intake
  • C
    Chryco Psycho reacted to Xcudame's post in the thread Any height difference? with
    Like
    Like
    I guess it depends on what carburetor you have or want to run. Personally, I'd use the 73 3671918 intake and build a good Thermoquad for...
  • S
    Thank you for the Info & the photos. The Relay must be missing because there is not one attached to my Fuse Box as shown in the photos...
  • S
    Surfcuda reacted to Slotts's post in the thread Power Window Relay with
    Thanks!
    Thanks!
  • S
    Surfcuda reacted to Xcudame's post in the thread Power Window Relay with
    Like
    Like
    If it's not missing it will be under the dash near the instrument panel, I believe. I never had an E-Body with power windows! It has a...
  • Katfish
    Katfish reacted to Slotts's post in the thread Power Window Relay with
    Agree
    Agree
