Latest activity
  • F
    Fordication replied to the thread Engine idle not working.
    Just checked it. 1.7 ohms and 12.8 oms and the 12.8 ohms is bouncing all over the place. Will not settle down. Bad resistor. I am...
  • Xcudame
    Xcudame replied to the thread INFO needed Keith Black Hemi.
    Almost all of the pictures of the bores show notches. I highlighted one so you know. Hopefully some of the Hemi guys will chime in...
  • heminut
    heminut reacted to Snowdog's post in the thread Old Superbird Pics with
    Like
    Like
    Here's some old Superbird pics from the 80's or 90's era. They had several superbird owners run their cars around the track at MIS...
  • F
    So I think you put me in the right location. Will let you know in a minute if the resistor is bad.
  • F
    No. I know where the ballast resistor is and the ignition coil condenser. After doing some research it would appear that both of those...
  • Cuda Hunter
    Cuda Hunter replied to the thread INFO needed Keith Black Hemi.
    I ask about the 413 because I have several industrial motors as well as a few 6 bolt motors. The bore is 4.25. The owner ran this...
  • Mr Cuda
    Mr Cuda replied to the thread Fm3 paint mix.
    Have you ever seen an 80's to 90's camero that was pink on top, red on the bottom? Red being the most expensive color had GM (ppg) make...
  • Xcudame
    Mains - 90 Sides - 80 That's the torque for the main cap bolts in ft-lbs. Obviously the block is notched to allow a stroker crank. Do...
  • S
    Steve340 reacted to Snowdog's post in the thread Old Superbird Pics with
    Like
    Like
  • pschlosser
    pschlosser replied to the thread Engine idle not working.
    I was thinking the manual would help you with the ballast resistor location, wiring diagrams, wire colors, etc. and other more common...
  • S
    Steve340 reacted to F8RT's post in the thread Been a while but have a new project with
    Like
    Like
    Sold my other 70 Challenger RT now i have this car now. 70 Challenger RTSE 383 4 speed in top banana Cal delivered car so very little...
  • F
    I have both service manuals but that does not help me. If I cannot find anything in the manual that says carb popping and stalling. So...
  • pschlosser
    I just checked the parts book. Interior Seating is tricky to navigate, but it looks like the seat bottoms are indeed different part...
  • Xcudame
    Xcudame reacted to Fordication's post in the thread Interior Paint with
    Like
    Like
    You will find that none of the cars have the same color on the interior from one component to the next. My interior is original and...
  • Xcudame
    Xcudame reacted to Mr Cuda's post in the thread Fm3 paint mix with
    Like
    Like
    As I've said before, the formulas don't matter if you don't have the toners. Every brand has a different strength, and tone. Here is my...
