Latest activity
  • M
    moparlee replied to the thread cooling combo questions ….
    Best to go with the factory proven HD cooling system. Seven blade fan with clutch, shroud, and 26" radiator and you can't go wrong.
  • M
    moparlee replied to the thread Hello from France !.
    Welcome from Michigan and congrats on your Cuda!
  • fasjac
    fasjac replied to the thread Hello Y"all.
    Welcome to the site from Arkansas!
  • moparleo
    moparleo replied to the thread rear height.
    Removing spring leafs could make the car dangerous in a hard, evasive maneuver. Anything that affects the suspension, has and effect on...
  • hdwrench
    my future set up on my restoration is a moderately camed 69 383hp , auto . i converting my 74 cuda build from 318/auto . i need to...
  • M
    Welcome from Michigan! Once you find your E-body start a thread on your project when you get underway so we can follow along.
  • moparleo
    moparleo reacted to Juan Veldez's post in the thread rear height with
    Like
    Like
    I am VERY disappointed. Of all the Dudes and Military Veterans on this site, and not one rude/sarcastic comment about rear height...
  • moparleo
    moparleo reacted to HPP's post in the thread rear height with
    Agree
    Agree
    Yep, from the factory, with equal size tires all around, the only E bodies that sat taller in the back were the AAR/TA twins. Everything...
  • moparleo
    moparleo reacted to 540HemiCuda's post in the thread rear height with
    Agree
    Agree
    Keep in mind that when changing the front spring perch height that you are also changing the pinion angle. Chrysler spent a lot of time...
  • moparleo
    moparleo reacted to Challenger RTA's post in the thread rear height with
    Agree
    Agree
    That's a question that you should have not ask. I will answer in short from what I know. Then duck. No B pillar or frame on an E body...
  • moparleo
    moparleo reacted to Xcudame's post in the thread rear height with
    Agree
    Agree
    The most important thing regarding ride height is that at rest on level ground, the leaf springs are just about perfectly flat on top...
  • moparleo
    Like
    Like
    You can lower the rear by raising the front leaf spring mount.
  • moparleo
    moparleo reacted to Katfish's post in the thread rear height with
    Like
    Like
    Might be easier to just add lowering blocks? Mine is around 26.5, don't like to see top of tire. https://postimages.org/][/url]
  • moparleo
    moparleo reacted to 62Dodge_'s post in the thread rear height with
    Like
    Like
    Howdy Here is a quick way to lower your rear, just flip your front leaf spring perches, it tucks the leaf springs higher up. It will...
  • Morpheus
    Morpheus reacted to pschlosser's post in the thread Too Tight Steering with
    Like
    Like
    Adjusting the power steering box seems beyond the scope of a front-end alignment. If the shop did indeed adjust it, I would consult...
