Latest activity
  • Semomopars
    Pending…. Actually going to the original car. Unbelievable. Thank you Jeff Bangert for finding the owner.
  • D
    duopoli reacted to MoparCarGuy's post in the thread WTB Road lamp bulb with
    Like
    Like
    You can get an aftermarket LED bulb that has the glass flutes which appear much like the stock bulbs. LEDs draw very little current and...
  • B
    Blackfoot88 reacted to pschlosser's post in the thread Fuel Pressure Bypass Regulator Connection with
    Agree
    Agree
    from the factory, your 1972 should have had the vapor separator. it is part of the ECS system that became mandatory in 1971. and it...
  • pschlosser
    I'm guessing it's less work to replace the boots, than disassembling and rebuilding the entire front suspension. If you're confident...
  • Kez
    Kez replied to the thread Headliner Hole Locations.
    THANKS - that was exactly what I was loooking for. Had seen it a while back and bookmarked the link from another thread, but the link...
  • Kez
    Kez reacted to pschlosser's post in the thread Headliner Hole Locations with
    Thanks!
    Thanks!
    I concur with Xcudame. install the headliner, then feel your way around, palpating to find the opening(s), like the shoulder belt and...
  • Kez
    Kez reacted to Xcudame's post in the thread Headliner Hole Locations with
    Thanks!
    Thanks!
    Assuming your headliner is installed, with the aid of the picture posted by @Juan Veldez use a tiny threading needle to locate the coat...
  • Kez
    Kez reacted to Juan Veldez's post in the thread Headliner Hole Locations with
    Like
    Like
    Someone else posted this a while back. Prop's to them!
  • pschlosser
    pschlosser replied to the thread Headliner Hole Locations.
  • pschlosser
    pschlosser replied to the thread Flock cameras.....BAD.
    TLDR; but a quick related story - about 5 years ago, I was hired to design software that counts traffic flow at intersections from the...
  • Katfish
    Katfish reacted to Xcudame's post in the thread Flock cameras.....BAD with
    Agree
    Agree
    I'm totally against all big brother surveillance. It's just so big now, that these Flock cameras are just icing on the cake. I will be...
  • Xcudame
    Xcudame replied to the thread Flock cameras.....BAD.
  • Xcudame
    Xcudame reacted to One of few's post in the thread Flock cameras.....BAD with
    Like
    Like
    Some employers have installed tag readers as well. I retired from Cleveland Cliffs, they have those cameras now. Seems everywhere you...
  • Xcudame
    Xcudame reacted to Katfish's post in the thread Flock cameras.....BAD with
    Like
    Like
    Well, that doesn't broadcast anything. GPS is a 1-way signal that any GPS receiver can pick up. It's entirely possible that a car that...
  • C
    Cav73 replied to the thread 73 Soft Pedal Learning Process.
    Challenger RTA, I see the valve stem is in the up position. Isn't this normal? From the FSM, pp 5-22 to 5-23, it looks like you only...
