Headliner Hole Locations
Kez
San Luis Obispo, CA
Working on installation of the headliner in my car and I cannot get any links to the hole locator diagram mentioned in several threads here to work - it times out without loading. Has it's location been moved or has that file been removed for some reason? I am looking for the holes where the coat hooks mount.
Someone else posted this a while back. Prop's to them!
I concur with Xcudame. install the headliner, then feel your way around, palpating to find the opening(s), like the shoulder belt and dome light. then make a small cut where the hole is found, AFTER the headliner is stretched into place.
that said, I generally make the dome light opening during the headliner install, and routing the wires, before it was fully installed. I do this so I can reach behind, and make it all nice.
I've used a soldering iron, my last time, to make the holes for the shoulder belts. I really like how it makes a clean hole to minimize fabric fray.
THANKS - that was exactly what I was loooking for. Had seen it a while back and bookmarked the link from another thread, but the link is not working now. Thanks everyone!
