Gator
- Joined
- Dec 21, 2010
- Messages
- 9
- Reaction score
- 0
ok here i go im new here so hello to everyone . im currently building the second engine this year for my challenger . Its a 383 bored .040 i installed kb 400 pistons with 452 heads . now my problem is i wiped out the first cam and now rebuilding again as metal distroyed the crank and bearings . I have read all about the low zinc in the new oils as i have finaly acceped that i used the new oil and was told it had enough zinc . so its really puzzling as to why the cam whiped out . I did the proper break in on cam 2000 - 2500 for 30 minutes then didnt notice the metal in the oil till it was too late it ate the bearings so bad the engine locked down , then i seen the metal on the dipstick . So now im taking all the precautions i can comp cams 280 h kit as comp says they wont warranty any part if i dont use all there parts . I have never ran into this before and have built several engines in my life time all fairly stock so this is my first attempt at a performance engine . any help on this would be greatly apreciated as i cant afford to rebuild this engine again .
