FOUND 4spd pedals
CR-MOPAR
Looking for a used 1970-72 pedal assembly from a 3 or 4 speed manual E body or 1971-72 B body.
Hoping to find a reasonably priced one to put a prevouisly parted out car back together.
Located in Canada
gzig5
Mequon, WI
Unless you find a good deal or need to have an original set, I think the reproduction sets are the best deal. Several sources online and on ebay all look pretty much the same. They would use the frame from the automatic and add the needed parts, pretty much like the originals did. If you will run an original style three finger clutch, you need the over-center spring.
Brewer's Performance - Mopar A833 4-Speed Transmission and Component Specialists
Brewer's usually has reconditioned OEM sets and everything else you could need for the system.
CR-MOPAR
I’m hoping I can find a good used setup at a fair price that I can restore. Although I might break down and just buy the reproduction coversion kit. I’m not going to pay the crazy price some guys are asking for ones that you still have to restore
gzig5
Mequon, WI
I'm in the same boat. The repro will work fine for me, but if I can find a deal on an original set, I'll go that way.
CR-MOPAR
Well I got lucky and found a very nice refurbished setup, it’s missing the return spring as it was used with a hydraulic clutch previously. $100 US plus shipping, so all said and done it cost me $220 Canadian.
