I just picked up a NOS 340 exhaust manifold, only because I got it at less than the cost of a heat riser kit alone. I have a matched set of restored coated manifolds already, and want to simply remove the heat riser assembly from the one I just purchased and reinstall in my restored one.
I'm assuming that if I carefully use a torch to heat the manifold that I can get the heat riser shaft inserts out, so I can then install the inserts into my restored manifold. Am I on the right track, or is there a different preferred way?
