WTB Challenger clips
hpjunke
Hi i was wondering if anyone has these clips that hold on the grille moulding for a 72-74 challenger . I found a couple , there is 8 total i need just 4
Thank you
I should add that Aveco makes all the moulding clips and most that are on your car are a universal.
one more post...I misspelled Auveco...you can obtain them from carpak.com. I just tested a Chrysler part number and if you have clips with a part number and a penastar you can put that into the search and it will pull it up
unfortunately i don’t know the part number of those clips
Chrysler did not put a part number on this clip. Chrysler's attitude was we have to buy them so you if you need have replacements to source your own. Those clips only came with the moulding. Again this is a universal clip and if I were you I would use the plastic clip in place of the metal clip. The metal clip is made of the same spring steel that binder clips are made from. And THEY RUST. Both clips have a tension arm to keep them in place and both work identically. This time use this web site car-pak.com
