doubleyellow
- 5/32 gap between the metal and rubber washer on the adjustment rod?
- Clutch pedal stands at least 1" higher than brake pedal at rest. Is this the normal height difference?
- The so-called "lock-nut" spun freely on the threaded rod. I took it off, crimped the ends a bit, and then added locktite. Should I have just replaced the nut? or it will stay in place due to the spring pre-load.
- I am able to shift through all the gears with the engine off, without engaging clutch pedal. I thought I needed to push the clutch pedal in order to shift through the gears. Please advise if I adjusted the clutch properly.
Tranny rebuilt by Brewers and all other components new...
Drivetrain was a mess when I got the car 35 years ago, so don't have the knowledge on proper tranny adjustments.
