Looking for a part
Welcome to the forum and greetings from Nebraska! :) Also, you would have better luck if you put this in the Challenger cuda parts wanted section! How bout a pic or two of your Cuda? Again, Welcome to FEBO! :)
Well, it is in the welcome wagon! So, Welcome and Howdy from Colorado.
So, you have a porsche. Are you restoring a cuda for someone else?
What your after will be simple enough to find.
Welcome to the site from Arkansas! I may have what you’re looking for. Just need to go through some totes. No promises.
Lets see some pics of your car when you get time.
1970 Cuda remonte Mirror cable bracket
Just to make sure, you looking for the ring behind the chrome bezel? I happened to open one box with miscellaneous stuff, I found this.
I bet it is the bracket inside the door by the lower hinge to keep the cable out of the way when the window goes down
That’s what I figured, just thought I’d put it out there since stumbled on the bezel. Don’t think I have that. Someone’s nomenclature varies at times. Lol. Thanks Chryco
