Frank Logan
After it rains the floors are wet in my 73 challenger. Its not a coolant/ heater core problem. What are the common spots to look for leaks on an e body?
The front floors. It is a vinyl top car so it is probably rusted around the a pillars. I need to replace the top anyway so ill pull it and have a look. ThanksFront or rear floors? Is there any rust around or under the windshield and rear window trim? Have you checked for rust holes underneath the rearward tops of the fenders next to the corners of the windshield? (This common rust spot is right below the base of the A pillars. See photo with rust hole below A pillar) Rain may also be entering through rust spots underneath the cowl. Where is the floor wet exactly?
Take the vent screens off top of cowel, look in at vent openings , check for rust holes. Had that trouble with my cuda. I had to remove and replace top to repair. On mine most of flange was rusted off.After it rains the floors are wet in my 73 challenger. Its not a coolant/ heater core problem. What are the common spots to look for leaks on an e body?
