Windshield Question
ken 408 Stroker
San Jose, CA
Where should you start the Butle Tape when installing a New Windshield in a 70 Cuda
Juan Veldez
Nampa, Idaho
I started at the top center OF THE GLASS and went all around and made sure I had a good contact at the connection of the ends. I'm sure there are schools of thought to start at the bottom center or even one of the sides, but as long as the two ends mate together real well, you shouldn't have a problem. I'm glad I installed it on the glass because the new rear glass was about 1/4" less in height from my original one and if I would have laid the strip on the metal frame, I'd barely have caught the glass. Do a dry run before you install the butyl strip to confirm fitment. Don't forget the spacers to maintain equal clearances and prevent sagging.
ken 408 Stroker
San Jose, CA
JuanI started at the top center OF THE GLASS and went all around and made sure I had a good contact at the connection of the ends. I'm sure there are schools of thought to start at the bottom center or even one of the sides, but as long as the two ends mate together real well, you shouldn't have a problem. I'm glad I installed it on the glass because the new rear glass was about 1/4" less in height from my original one and if I would have laid the strip on the metal frame, I'd barely have caught the glass. Do a dry run before you install the butyl strip to confirm fitment. Don't forget the spacers to maintain equal clearances and prevent sagging.
Juan, thanks for the Information, Much Appreciated, I'm going to drop in tomorrow, thanks Again
Good advice above. Be sure to use a setting blocks on the bottom.sets the height for one.second on a warm or hot day will slide down. Feel the inside or outside bottom of windshield. not a constant curve.
pschlosser
Santa Rosa, California
I put mine in starting the bead at center bottom and working around. The bead was long enough I could cut to fit and jam the ends together so there was no gap.
cuda joe
nj
start it at the bottom .. if it leaks when at the top water gets in the car
