sdcbowler
- Joined
- Jun 4, 2015
- Messages
- 190
- Reaction score
- 48
Hey Guys,
Trying to track down why I keep blowing the tail light/cigar lighter fuse. With the exception of the reverse light, all exterior lights work fine until I plug in either one of the front side marker lights.
I was comparing the aftermarket harness (M&H) to my original and it appears to be the same. However, when compared it to the wiring diagram I noticed a small difference. I would appreciate an opinion from the forum.
In the diagram below, the blue lines show the configuration of the new harness, which matches the original. The red ‘scribble’ of course is the wire runs in the original wiring diagram.
My question is: Do you think the harness is built correctly and the wiring diagram is not totally accurate in terms of the wire positions as they enter the plug, or is the harness built incorrectly?
For example: The diagram for the front left marker shows (L6-18BK/Y*) going into the female socket side of the connector and (L9D-18BK & L6A-18BY/Y*) both going into the male plug side of the connector.
Yet, the picture of the new harness shows (L6-18BK/Y* & L6A-18BK/Y*) going into the female socket side of the connector, and the single (L9D-18BK) going into the male plug side of the connector.
The left park/turn signal and the right marker also show a difference between the harness and the wiring diagram.
Thanks in advance
Thanks in advance
