70 Challenger 4 speed floor pan brace cut
RTSE70
North Idaho
My 70 Challenger has had the floor pan brace cut to clear the a833 speed trans shifter linkages, leaving the trans crossmember secured with 3 of 4 bolts. I can't believe this is correct but have not found anything in the parts or repair manuals showing the trans installed. Can anyone point me to a photo of the correct mount installed?
RTSE70
North Idaho
The crossmember should never be cut , the linkage clears above the crossmember
It's hard to get a photo of but the crossmember is intact but the floor pan brace it bolts to is cut and looks like if it were there, the shifter could not mount.
Steve340
New Zealand
Something about yours is not right but I can't put my finger on what it is.
My original 4 speed car uses all 4 bolts.
If post enough pictures. I might nail it.
Take note of the installed linkage.
RTSE70
North Idaho
Pan Handle West Virginia
Although an A-body mine was cut as well. A B-body 4-speed was used in the car and my FIL cut it to fit the trans for whatever reason. I found a cross member and we cut and welded the missing piece back in.
sixpak2go
NC
Rons340
Tennessee
Mine had been hacked out like that when I got it! I had to get a new one from AMD and replace it. Fortunately I had to replace the floor pan too so it wasn't that big of deal!
