Gran Coupe Rocker Moldings
Xcudame, if that funky clip you have is 1 3/4 inch. Winner, winner chicken dinner. Need 10 of them
If this clip is available, and someone needs them, they should buy them.
They look correct.
A picture off my rocker trim also.
So these are correct then? Do I need 8 or 10? Also, any idea how large a hole I have to make in the rockers to accommodate these?
Thanks!
I picked these up a few years ago and they match the single that I had. It takes 5 on each side with one screw on each end. It looks like a 5/16 hole, but don't hod me to this. The car is up on a lift so I can get you a more accurate diameter later. I might have picked up an extra one or two just to have.
There are clips that hold it on as well as the 2 screws on the ends. My clips were wide white plastic clips that screwed to the body. Perhaps they were not original and were used after the car was painted many years ago.
I should clarify that the clip picture I posted to compare with the new ones that were available, are for 70 GC.
71 clips are different, and I can't say I've ever seen a 71 GC.
