Hello again!
Back with another question. I recently installed a Holley Sniper 2 on my 440 and afterwards have had a major oil leak once the engines warm. Its leaking near the front timing cover but hard to pinpoint exactly. If I let it keep running, it would probably dump a quart in 30 minutes.
I'll give a timeline of what I've done to see if anyone can help narrow it down.
About 2 months ago I installed a new oil pan (https://www.summitracing.com/parts/TRD-9496) and a gasket/windage tray (https://www.summitracing.com/parts/SUM-G2339) to fix a small oil leak I was having. After this install I wasn't having any noticeable leaks but probably only ran the car 5-10 times over 10 minutes.
A month ago, I started the install of my holley sniper kit, it took about 2 weeks because I had to wait on different parts to come in. This entailed: replacing mechanical fuel pump with electric and using a block-off plate, swapping carb with sniper unit, swapping distributor with hei hyperspark, wiring, coils, etc.
The leak started immediately after my conversion.
I initially thought somehow I maybe warped the pan during testing by maybe running it a bit hot, so I swapped to a traditional gasket and some additional rtv, but the issue persisted.
Then, I thought maybe my block-off plate wasn't sealing right, so I reinstalled it with a new gasket and rtv, but that didn't fix it either..
Now that I'm typing this, I'm wondering if it's possible it might be coming from the distributor... it's hard to pinpoint, just that it dripping from front edge of the oil pan where it meets the timing cover. Could definitely be coming from higher up, but not from the valves or anything..
I left it at the office today, but I can check the distributor better tomorrow(office is 15 mins from home and thought that would be a good test because I thought the issue was resolved)
Is there somewhere else I should be checking? Thanks!
