K FRAME
gf7cuda
Hello Mopar friends, I was installing my engine this past weekend and had an issue with lining up my K frame bolts (3 ok \ 1 not ok). I built a jig and installed from the bottom with transmission attached. The main question is, with the weight of the engine/ trans already on the K frame, alter the bolt holes line up? This is a recent K frame I purchased and had it restored and had no damage to it. To take it one step further, the original one I had to put back in because my new purchased one wouldn't line up also gave me a hard time lining up until I took the weight off K frame with a screw jack. Has anyone experienced this problem?? Thanks in advance.
The factory K-Frame wasn't the most rigid piece! That's why people weld gussets into them and weld all the seams. So yes, your engine/trans weight could very well be distorting your K-Frame. You could try disconnecting the motor mounts and jacking the engine up with a floor jack a piece of plywood between the jack and oil pan. The removed weight may let you get all four K-Frame bolts in.
Rich Followell
As a retired frame tech the first thing that comes to mind when I hear something like this is bent frame! Have you tried a diagonal measurement between the bolt holes? they should measure exactly the same. try this on the body and on your subframe. if you have a slight difference of 1/8 I wouldn't worry about it but because you have to divide that number by two leaving only 1/16 of a difference. But if you find a 1/4 or greater you could have a problem. also measure the length between the holes on each frame rail they should be the same if not ergo an issue!
pschlosser
Santa Rosa, California
The only time I've had issue with K-member to frame alignment, was when the K-member came from another car. In those cases, I may have been guilty of bolting just the K-member to the frame rails, and doing what I can to get them to align, such as loosen/remove fender, bumper, etc. Only AFTER it's bolted and torqued, will I add the motor-trans and suspension.
From the bottom, like the factory does with the motor-trans and suspension, I'm confident they have supports in place on the trans and wheel hubs to evade undue stress on the K-member.
If you're K-member came from this same car, it may not be that far out of whack.
Once your K-member-engine-suspension assembly is between the frame rails, lifting the engine-trans by carb plate (for example) may remove enough stress or "tweak" to get things aligned enough to bolt together.
While it's a PITA, as others suggest, see if you can find where the "tweak" is.
1. compare bolt hole cross measurements on the frame rails.
2. compare bolt hole cross measurements on the K-member.
If things are pretty straight, they should be within 1/4-inch more or less.
gf7cuda
Thank you for your advice. I will check this out. Appreciate it
gf7cuda
It did come from a B body , but b/e body should be the same I believe, I could be wrong. Came from a 71 Roadrunner
HooToTheCore
Charlottesville, VA
B body k-frame will have a 2 degree angle difference in the steering gear to steering column alignment. It will also not support an e-body sway bar. Other than those items, it can be used on an e-body.
gf7cuda
I had to do that and it worked to get the old one back in. The jig I made supports the outer edges of k frame. So the middle under engine is open and not supported.
gf7cuda
So they are different? My build sheet has 52 for frame and this K frame has a 52 coin on the front. I thought I seen somewhere 71 e/b body is same. I could be wrong...
This might help. Install K frame bolts that line up and check to see where it is out. Use a tape for these measurements. 38 1/8" and 54 3/8".
HooToTheCore
Charlottesville, VA
This may be the case for '70 and earlier B-body k-frames. I know my '70 Challenger had a k-frame that should not have been on the car. I tried to add a sway bar and the k-frame required the bar to pass in front of the k cross member, not through the cross member. I swapped the k-frame for an e-body frame and the sway bar installed correctly.
Someone with more knowledge than me may know for certain, but I think 71 and 72 B bodies share a K-Frame that can interchange. 70 and prior, the B-Body had the different steering box attachment angle and sway bar mounted different as mentioned above. 73 and later B-Bodies had the weird biscuit rubber suspended front suspension that changed geometry again.
aussiemark
Perth Western Australia
The frame rails, firewall, cowl and inner fenders are the same on 71 B bodies /E bodies the K frame should be the same I would have thought.
brotow
L.I. N.Y.
this how
i installed my drive train. Lowered the car to the k frame which was on a custom dolly, fit perfect. Originally a /6 now 340 6pak.
