wipers blow fuse
7DCUDA383A
60 Miles West of STL
1st of all Im not sure if they worked before I took it to the shop but they installed all new wiring under dash and engine bay , everything works now except the wiper keeps blowing a fuse when turned on , the shop says its internal and the wiper motor needs replaced , does this sound like a motor issue .
Did you try to unplug the wiper motor from the bulkhead connector then turn on the switch and see if the fuse still blows?
Yes the shop did do that , I just read alot different issues with the wiper system and wanted some real Mopar advise which this forum is incredible at , the motors range from cheap to expensive , I doubt that I ever drive in the rain but you never know .
It can be pricey to have your existing motor serviced, painted, plated, restored, and fully functioning and looking like new. For some repainting their cars, and going through the restoration process, it is worth it.
The motor will blow fuses when it's pulling too much current. It does this when it gets old, and the internal bearing surfaces are drying up. Also, the arm mechanism it drives can be getting harder to move. To repair, one pulls the motor and services it, or replaces it with another used one. In the process, the mechanical parts inside the cowl are inspected, greased, tested, etc, to make sure their in top working order.
You can drop a new reproduction motor in, but that may be just as pricey as having your old one restored. Plus, if the friction and current draw is caused by the arms functioning poorly, or even jammed up, you may cook the new motor.
You've got some work ahead of you. But, there is a long shot it's simply a short. That would actually be a good thing, if it was a short, because fixing the short will be considerably less work, maybe even less expense to repair.
So, as EW1BH27 says, test this by disconnecting the wiper motor, and activating the switch to see if the fuse blows. You said the shop did this? Okay, then seek a second opinion. Do the test, yourself. You've got much to gain if it's a short, and lots of time and money to lose, if it's not a short, and the motor or mechanism is the problem.
Out of curiosity, is it a 2 speed or variable/3sp setup. I’m having trouble making it out in your avatar.
You can drop a new reproduction motor in, but that may be just as pricey as having your old one restored. Plus, if the friction and current draw is caused by the arms no functioning well, or even jammed up, you may cook the new motor.
The shop is fixing one more issue then I'm finally getting it back , I told them I'll fix that issue , so I will be checking all components , thanks again for the info pschlosser .
Oem style harness, MH harness or other. What fuse and where.
EW1BH27
A definitive answer helps.
The 2-speed motor sticks out straight and points forward into the engine compartment, while the 3-speed is turned, and protrudes toward the master cylinder.
