Best products to clean plastic lenses?
gran coupe john
Ohio
Got original dome lens. Really don't want to spend 50 + shipping for a repop that might or, might not work?? Anyways is there something to soak it in, or to clean it up? It will never be perfect. Just wanting it to look better than present condition. Already been cleaning it with windex for last 2 hours.
keep in mind 50-year old plastics are brittle, and can crack and break easily. more easily that you would think, so handle it with gentle care. a newer repop still has some flexure. the older stuff does not.
if that brown is rusty metal residue, you'll want to get that off first, as the grit may scratch the plastic as you clean it. for this, you can soak it in straight (5% off-the-shelf) kitchen vinegar. or something stronger, if you want. I often use an old credit card as a scraper. In this scenario, after soaking, you can scrap the metal off, and resoak until clean.
next is your basic soap and water. you want to remove as much or all of any dirt as you can. I like using liquid dish soap and water, mixed 50/50. if there are crevices, an old tooth brush works great. I even have an old sonic toothbrush I use on occasion.
finally, treat the fine scratches. that is a textured (ribbed for her pleasure, in this case) lens, so it may not show any fine scratches. but a side marker light, instrument cluster cover, or tail light lens may. fine scratches can cause a haze. for over 20 years, I've been using an aircraft (most have plastic windows) acrylic plastic cleaning product that comes in three bottles. similar to this product from Amazon. it removes the scratches that can be removed quite well. just takes patience and a little elbow grease.
Hopefully you'll get it cleaned up satisfactorily but I had the same problem with quite a few of those overhead console lenses, I made some headway but in the end sprung for the repop. I tried some bleach along with soap and water. The old plastic discolors from the heat of the bulb over time. Vans Auto has them on ebay for $40 I think, they actually do fit well. Ah the fun of the SE / Gran Coupe cars... I probably have some extra lenses around still from the ones I replaced so if you're not happy with what you end up with send me a message and I can dig them out and see if any are better.
Thanks for offering them to me. I have been tinkering with the lens all day. Starting to look better, but really won't be happy. Time will tell.
After soaking, the brown around the edges is not rust. Found out the brown is glue.The housing has zero rust. Although the glue is a b to get off.
Agreed, you have to live with the yellowing. I've not found a technique to remove it, and it seems to go deep into the plastic. Even when all the tabs are still in place, I've had them bust off (presumably because of age brittleness) during final assembly.
For a survivor car, a yellow lens is fine. For a nice restoration, go with a repop.
I'll check my stash in the next day or two and see what I come up with.
Mild paint/clear coat polishing compound works great on plastic. It’s just abrasive enough to remove yellowing & fine scratches, and will lightly polish the surface. I’ve used it on the clear gauge faces, tail lights, plastic head lights, etc. I use a soft towel or old t-shirt and hand polish these things, except for the headlights, then I use a drill with a pad.
@gran coupe john
Here are my extra old lenses. I can't send pictures in a private message so I figured I'd post one here. Probably the bottom left or middle one would be the best of the bunch. The top two being the most yellowed, and the bottom right one seems to have some weird waves or something going on in the plastic.
They all seem to have most of the tabs broken off so would need to be glued in.
Also sending you a PM.
The one that was on the car was also glued in, only had 2 tabs left. Really don't want to glue that part back up. The tabs must be the weak link. Wondering how many tabs on a complete one. Thanks for pulling those out, and getting back with me.
No problem. There are supposed to be 10 of those little tabs altogether.
