4spd and Automatic Driveshaft the same?
gzig5
Mequon, WI
I’m converting my 73 Cuda from an automatic to manual transmission. Going from a 727 to an A833. Will I have to do anything with the driveshaft to accommodate the four speed or is the same length used in both applications?
Thank you. That chart didn't specifically cover my year/model (73 Cuda 340/727), unless I missed it, but it told me what I needed to know. If staying with the same engine, it is most likely that the original driveshaft should work with either transmission. I can compare the two when I get home, but that should be one less thing I need to worry about.
