Pickup tube to oil pan depth
7DCUDA383A
60 Miles West of STL
I ordered the 6qt hemi pan and 4 1/2 pickup tube from 440 Source , the pickup tube in snug is more like 4 1/4 and the pan is 5 in . I can get it to 4 1/2 but the tube is not tight , with the extra oil in the pan , 7 qrts , is it ok to be 3/4 to a 1/2 in. off the pan bottom , thanks again for any info .
What Cryco said. The pickup should touch or just about touch the bottom of the pan. I would call 440source and discuss your issue with them.
I just wasn't sure about the extra oil in a bigger pan if it could be higher off the bottom of the pan , I might just return it and just go with the 402 pan I have , im sure it's fine for weekend cruising.
I've got a similar current issue. I just plan on a little bend to make it work. I bought the 6 qt pan and pickup that 440 source recommended, along with their stroker windage tray. All three pieces are going to take some work to make them fit. The stroker tray touches the center of the pan so it doesn't sit flush against the block, and the pickup doesn't fit through the slot in the tray that they say it will. I'll make it work, and it will take less than an hour, but it certainly isn't as good as their descriptions say it is.
Yes I agree , Im new to this mechanic engine stuff so Im learning alot from everyone here , I did have to cut out a hole in the wingage tray for the bend in the tube , mine is from Summit with the gasket attached to the tray and Im just going to use the 5qt ''402'' pan , the tube matches perfectly to that pan .
......I'll make it work.........
Out of the box, what if you shorten up the tube and add such as this for the necessary length?
I'll tell 'ya what is so frustrating to me; we buy (expensive) parts and they don't fit without alteration. Seems the norm these days.
Some good reference in these for beginners....
Manual downloads here.......
Got around to fitting mine up yesterday. Windage tray took some cutting to make it work and the pickup tube took some bending but not much. I just threaded it in until it was bottomed out and was able to pull up and back on it to move it a tiny bit at a time. Checked fit with pan against the rails until it was lined up just right. Easy!
Windage tray I had to remove some metal from the middle and rear louver in the bottom as it was hitting the baffle in the 440 Source heavy duty pan. No big deal and easy enough to make work, but annoying that they say it'll fit right. Oh well, all better now.
This is just how hot rod building goes and it's worth it in the end! 😁
I tried my best but I started at the trans because I knew the k-menber holes would suck , my last hole I couldn't get the bolt in , I kept trying then heard a piece of metal drop in the pan , so I took it off and found the little metal ring broke off on the gasket , which is rubber with metal rings , so I just went with my 1st option and used a regular gasket , it's just for cruising anyways , very hard to do on your back in a garage but it is fun to do , now trying to get the center link back on and the idiot that put it on used miss matched nuts , not me , I keep telling people this car was put together in a junkyard , it looks killer though , just alot of time and money getting it together , oh well , Happy Mopar-n.
how we did it put in pickup tube so you know it will hit the bottom of the pan a little put the pan on to push the pickup remove pan move it 1/4 inch away from were it hits the pan and weld it so the pickup doesn;t move
