Voltage Limiter
Logger10
Port Alberni BC Canada
Can someone please tell me the function of the voltage limiter in a 72 Challenger Rallye dash? Mine is not serviceable, I have one ordered, My guess is the fuel, oil px .......guages need a lower voltage to operate? Thank you.
When the instrumentation for our 60s-70s MoPars was designed, electromechanical devices were still far less expensive than semiconductor devices. That is why mechanical voltage regulators were used. Today, we can buy a semiconductor device for pennies (I remember paying DOLLARS for what is now a crude transistor). It makes no sense to stay with a mechanical regulator for your dash gauges, especially when you've updated to the MoPar Performance electronic alternator voltage regulator. To my knowledge, no one (yet) manufactures a retrofit regulator for the instrument clusters. But, with modern integrated circuits, it's relatively easy to fabricate one for yourself!
Before getting into the modern era, it might help to understand how the old type worked. There were two physical versions used on MoPars (they work identically). The A-body version was part of the fuel gauge; the others used a separate unit that plugged into the instrument cluster's printed circuit board.
Foot note: MoPar Instrument Cluster Regulator Update
The nominal 12 volts of the car's charging system is regulated down to (approximately) 5 volts by a thermal "bimetallic" regulator, similar to that used in a home heating system thermostat except that, in this case, the bimetallic strip is heated by a nichrome (nickel-chromium) wire element.
As the heater element heats up, the bimetallic strip bends. When it bends enough, it opens a set of contacts - interrupting the output (and heater) current. The bimetallic strip then cools and closes the contacts, beginning a new cycle. The up-and-down voltage variations are smoothed by a capacitor (condenser) connected to the output. Over time, the contacts wear, and the heating element can go open. This is when your temperature, fuel, and oil pressure gauges stop working. Even when they are working, they tend to fluctuate up-and-down. It was a crude system but, at the time, it was the best thing available.​
The New Regulator​
In the modern age, integrated circuit chips do a much better job of regulating voltage and they're very easy to use. MoPar Action Magazine presented their version of this conversion in the August 2000 issue, using the LM7805 (5 volt fixed-output) 3-terminal regulator IC. While it'll bring back your instrument cluster back from the dead, you may want something with a bit more flexibility. Because the senders and gauges vary somewhat, it'd be nice to be able to set the output of the regulator to compensate for these tolerances. That's covered by another 3-terminal regulator - the LM317.
The new circuit...​
IC Voltage Regulator Cicuit
LM317T Connection Diagram (front view)
LM317
VOUT
R2
3.61​
510W​
3.84​
560W​
4.12​
620W​
4.40​
680W​
4.72​
750W​
5.05​
820W​
5.46​
910W​
5.88​
1000W​
6.34​
1100W​
6.81​
1200W​
7.27​
1300W​
8.19​
1500W​
8.66​
1600W​
9.58​
1800W​
10.51​
2000W​
11.44​
2200W​
Bill Of Materials​
C1​
10µF, 16V Tantalum Capacitor​
C2​
1µF, 50V Tantalum Capacitor​
C3​
1µF, 16V Tantalum Capacitor​
D1​
1N4002 Diode (or any 1A diode)​
R1​
270 ohm, 5%, ¼ watt resistor​
R2​
5%, ¼ watt resistor (see chart, above)​
U1​
LM317T Regulator IC​
Misc​
  • TO-220 heatsink (or small piece of aluminum)
  • 1000 ohm trimmer potentiometer (optional)
  • perforated circuit board material
Building the circuit...
The physical layout is not very critical at all - and it can be built on a small piece of perforated circuit board, or point-to-point. To realize the 1.5A capability of the IC, you must use a heat-sink of some kind. This can be either a store-bought type or just a small piece of sheet aluminum. C1, C2, and C3 should be "tantalum" types (don't use aluminum electrolytic types). If you can't find the exact values, somewhat higher values are OK - it's not too critical. Don't use lower voltage types, especially for C2. The resistors can be ¼ watt, ±5 or 10% tolerance types. D1 is specified as a 1N4002 (1A, 100V) rectifier diode but can be any 100V (or greater) diode rated at 1 ampere.
The National Semiconductor data book specifies 240 ohms for R1 but that is not as easy to come by as a 270 ohm resistor so, the chart (above) shows the calculated output voltage based on the latter. If you'd like to be able to have a variable rather than a "selected" voltage adjustment, you can use (say) a 510 ohm resistor in series with a 1000 ohm potentiometer in place of R2. That will give you an adjustment range of 3.61 to about 8.2 volts. It's only a few pennies more.
IMPORTANT NOTES:
  1. Before installing the new circuit, remove the old regulator.
  2. Since the mounting tab for the U1 is also the output terminal, the heatsink MUST be electrically isolated from everything else!
  3. Observe the polarity of C1, C2, and C3. Some vendors mark the positive terminal; others mark the negative terminal.
  4. When making connections, use a low-wattage soldering pencil; DO NOT use solder that has an acid-core flux!
How it works:​
The '317 is an adjustable regulator with 1.5A of current capability - more than enough to handle the ½ ampere of current demand by the gauges. R1 sets the current supplied to the adjustment terminal of U1. R2 sets the output voltage. C2 functions to remove any noise on the input of the 317. C1 serves to improve "ripple rejection". C3 serves to improve transient response. D1 protects U1 in the event the output is shorted.​
Summary​
I found out that having a heatsink is important. Though the regulator is rated at 1.5A and my gauges draw less than ½A, the regulator IC went into thermal shutdown after short periods of operation. After correcting my faux pas of not having a heatsink, it's worked quite well for some time. Short of installing aftermarket gauges (destroying the OEM look), this was an idea that was well-worth the effort.
Logger10
The New Regulator​
The new circuit...​
LM317
VOUT
R2
3.61​
510W​
3.84​
560W​
4.12​
620W​
4.40​
680W​
4.72​
750W​
5.05​
820W​
5.46​
910W​
5.88​
1000W​
6.34​
1100W​
6.81​
1200W​
7.27​
1300W​
8.19​
1500W​
8.66​
1600W​
9.58​
1800W​
10.51​
2000W​
11.44​
2200W​
Bill Of Materials​
C1​
C2​
C3​
D1​
R1​
R2​
U1​
Misc​
IMPORTANT NOTES:
How it works:​
Summary​
Huge information! Thanks for the quick reply!
I think you completely understood from your question. Just need an explanation. Remember if you have any trouble. The dash grounds are thought the defroster bolt, steering column , dash A pillar mounting bolts. Path of least resistance. Then the cluster and lights get it's grounds from the mounting screws.
Logger10
MoparCarGuy
Within the last year I had a local buddy in need of an IVR3 from RTE but their was a supply delay. I had mine on the bench and gave it to him until his order arrived.
That took weeks. High demand/low production parts are like that.
Hopefully, you get an answer shortly but RTE is a reputable vendor and I would not worry too much.
Logger10
Thank you sir!
MoparCarGuy
If anyone has been following this post, my Voltage Limiter arrrived from RTE, I installed it and flashed it up. Seems to work fine.
@Logger10
One thing I noticed immediately after the solid-state IVR installation was that my fuel gauge now registers perfectly FULL after a fill-up. I attribute the newly found accuracy with having a true 5VDC at the gauges versus about 4.4 volts with the original, mechanical IVR.
I have owned my Cuda for 41 years and the fuel gauge has never shown FULL. It was always about 7/8 max even with a new Tanks, Inc. floatless fuel sending unit installed when I put on the Holley Terminator X Stealth EFI. I can assume the other gauges are also now more accurate. A true win-win!
Glad you got your IVR delivered.
Logger10
@Logger10
