1971 dodge challenger center console compartment help
RickyOG90
Tampa, FL
Hi all,
Im working on creating a mod where i 3d print a module that will have switches and such that would slot inside the center console compartment; however, I live in another state from where i have my car stored during my restoration process and I dont have anyone reliable to do it for me, and the next trip would be middle of next year. Could anyone on here assist and provide me the internal dimensions of that center console compartment without the lid? like what are the dimensions of the bottom interior of the compartment, the depth of it, the top dimensions, that stuff. Also from my pictures I took at the beginning of the year, it looks like the interior walls angle outward so if you could also measure the height from the bottom edge and the length from the top lip to that height that way i can calculate the length and angle of those angled walls. Or just the depth and length of the angled wall itself as i can extract the data that way too. While this is for a 1971 dodge challenger, i think all years from 70-74 have the same size compartment, but not certain.
thanks greatly in advance!
slot inside
Sit inside? Or other. I miss a key or hit the wong key. SEE! Yeah I know your an :poke:engineer too if I remember.
If I recall someone 3D printed the top plate for the center console for cup holders. They might have a STL file for what you want.
Think I found it.
Sit inside? Or other. I miss a key or hit the wong key. SEE! Yeah I know your an :poke:engineer too if I remember.View attachment 147548
ha looks like i have a bit of notoriety on here already lol but yea sitting on the inside so i can still close the compartment lid so it would look stock when closed but pop it open and now you got toggle switches(one for fuel pump relay), 20w wireless charging pad, cig lighter charger, usb-c 65w and voltmeter, all that good stuff. i managed to get some dimensions but im unsure how accurate the numbers are so caliper measurements help greatly :D also would help to identify how high up the latch and hinge are so i can work around them
Think I found it.
thanks, i will look into that, i did send a message their way to see what they ended up making as its possible they only designed the lid and not the compartment itself. fingers crossed they did both! 😅
