Advice on removing door trim
Kansan
What is the best way to remove the trim from the top of the door? I believe it is called a belt molding and I notice there is a nut holding it on at the aft side of the door. Does it just slide off, or is there a specific technique needed?
Thanks,
Kansan
From memory, the molding is held in place at one end, the latch end (not the hinge end) by a clip screwed in place. remove the nut, and the molding will then slide backward 1/2-inch to release all the clips holding the molding. The clips are often plastic and brittle. they may break during removal. sets of these clips are available aftermarket.
I got it off with a trim tool...didn't realize they slid a bit, I had one break so I will be ordering a set, IF i can find the correct clips
Kansan
I’ve ordered the door belt moldings for my ‘70 Barracuda convertible as I want to add them to my car that did not originally have them. How many holes need to be drilled into the door to install them? Thx
3 on doors 2 on 1'/4s. = 10 That is if I recall that right.
I'm told NAPA part #665-1957 works for clips
Trim is coming with hardware. The convertible already has the quarter panel trim, just gotta hang the door pieces. Thx for the info.
On my Challengers there is a retaining nut at the front and at the rear of each door. The rest of the molding are held on with retaining clips.
