1970 Hamtramck - Chassis Parts Color Guide
Lunchbox
USA
I am getting ready to start having the below items powder coated/painted and wanted to check proper colors and sheen. I am thinking that anything that is bare steel will be painted to replicate that look. Some of the colors below were taken out of the Authentic Restoration Guide, Challenger & Barracuda Restoration Guide 1967-1974, would like to check correctness of them. Will add to the list with anything I missed and update this first post. Thanks in advance.
I'm specifically looking for a 1970 Hamtramck built car, but can expand as needed.
Front Chassis
K-Member – Semigloss Black
K-Member to Valance Brace – Semigloss Black
Front Sway Bar – Semigloss Black
Front Sway Bar Brackets – Semigloss Black
Front Sway Bar Saddles – Bare Steel
Torsion Bars – Semi Gloss Black
Torsion Bar Adjuster Bolts & Threaded Block –
Upper Control Arms – Bare Steel
Lower Control Arms – Bare Steel dipped in cosmoline to the outside rivet
Strut Arms – Bare Steel
Steering Knuckles – Bare Steel
Disc Brake Caliper Mount – Bare Steel
Disc Brake Caliper – Bare Steel
Disc Brake Rotor Shields – Semigloss Black
Shocks – Gloss Black
Drag Link – Bare Steel
Front Suspension Consumables (Tie Rods, Tie Rod Clamps, Ball Joints, Etc) – Bare Steel
Rear Chassis
Leaf Spring – Semi Gloss Black
Shock Plates – Bare Steel
Leaf Spring Hangers – Bare Steel
Rear Sway Bar – Semigloss Black
Pinion Snubber – Bare Steel
Rear Axle Housing – Semigloss Black
Drum Brake – Bare Steel with Red paint on front
Drum Brake Rear Baking Plate –
3rd Member – Bare Steel
Misc Items
Transmission Cross Member – Semigloss Black
Transmission Isolator Mount – Semigloss Black
Rear Tie Down Brackets – Bare Steel
6 Way Seat Under Floor Brackets –
Front Bumper Brackets – Semigloss Black
Rear Bumper Brackets –
License Plate Bracket – Semigloss Black
Inner Fender Access Panels – Semigloss Black
Battery Tray & Bracket – Body Color
Steering Column Shaft – Bare Steel
Steering Column Coupler – Bare Steel
Drive Shaft – Bare Steel
Valance brace to k member - semi gloss black
Upper control arm bare steel or gloss black
steering knuckels - bare steel
Struts - bare steel
Shock plates - bare steel
Leaf spring hanger - bare steel
Rear tie hold down brackets - bare steel
Since different factories did things differently, to be perfectly factory correct, you need to ensure you're using what was done at either the Los Angeles plant (70 only) or the Hamtramck plant.
I love the list! It will be a great reference source! Thank you for putting it together!
This is a B-body link, but perhaps similar
These were posted somewhere for a 1970 Challenger. Not sure who the OP was.
Great point I updated first post to specify 1970 Hamtramck built car.
@larry4406 great info what magazine is that from? Will take me a little time to pull all that info out and summarize it in the first post. Thanks!
It appears it was from Mopar Action. Link bellow lists it as from their Issue #7 of reissues.
Not sure where I originally snagged it from. I am guessing from Moparts way back when.
First post updated with 70 Hamtramck specifics. Please post corrections/additions. Thanks all!
original 6 way seat underfloor brackets were semigloss black, mounting fasteners were natural metal.
Thanks for the update, where the backer plates bare steel or something that was coated. Below are my originals, as is and the other after 24 hours in Evaporust.
