signal switch and key buzzer sw
eabodywkr
wi
Still working on my 73 column, seems like a lot of small issues that I do not see being discuss. I purchased a signal switch from Roseville, two things that are different from original. The contact for the horn sw, which I knew about, and the stem for the signal arm. The stem has a slot cut into the back side (see photos) from the factory the slot has a wide taper cut. The replacement has a narrow straight cut, the stock arm does not mate to this part. Roseville says they have sold hundreds of these, so I can't be the first one to see this. I'm thinking I will have to modify the new switch stem to accept the arm. Has anyone delt with this??
Also I had two key buzzer switches that appeared to be good, but tested bad. These switches are riveted together from the factory. On line they are very pricey, at least the ones I found. I took both mine apart, cleaned the contacts and put back together. The issue is the rivet, which you could probably replace with a very small screw. I only drilled the drilled the bead off the rivet and reused it with some JB plastic welded both sides of the rivet when putting it back together (see photo). It seems solid and I don't think it will be an issue. Is this switch available anywhere at a reasonable price?
If it were me, I'd file the tang on the arm a little thinner just because it would be easier to do.
I like your buzzer switch repair. Don't worry about a new one until you discover if your repair worked or not. They seem to be only available as NOS (high dollar) or used which may or may not be any good.
Yeah, I'm debating what to file down. The arm is still original, I know I can get access to file the switch tower. I am hoping someone else has seen this, because they claim to have sold hundreds. They also told me there are other brands available. This one comes in a white/blue/yellow box from Cub genuine parts (Taiwan) part number B026-003NA1-000 422-1103. I think they said they get them from Vans.
