ATK vs Blueprint small block crate engines?
TeeScott
Bardstown, Ky
Gents, I am at a cross-roads with my 73 340 auto challenger. Car has the original drivetrain with 93K miles and runs/drives fine. Engine does not appear to have ever been pulled or worked extensively (original heads, 50-year old internals, etc..). It has some minor blow-by that results in "sporadic" bad odors drifting into the car while driving down the road. It does not noticeably burn-oil/smoke at all, but the sump level does drop slowly (~1 pint) between oil changes. So,....I am currently getting a variety of work done on the car by the Finer Details shop in Indianapolis, and am evaluating options with the staff there to either rebuild the engine OR, swap in a crate 360 magnum-style engine and keep the original engine on a pallet so it can stay with the car for future work/selling with the car someday...
QUESTION: ATK's Crate 360s versus Blueprint's 408 stroker? I hear lots of good reviews on Blueprint engines, but have no direct experience. I also don't have any experience with ATK engines and don't find a lot of reviews/comments. Cost is always a factor, but my goal is to have a reliable, fun cruiser that will lay some decent black marks once in a while and pull similar to the 68-70 340 engines. Comparing long block prices: ATK's 360 magnum with 350 HP 410TQ 360 goes for $4099; while Blueprint's 408 stroker magnum with 375HP, 460TQ flat-tappet magnum goes for $7599; Just not sure that a price difference of nearly twice as high to get into the stroker would really be worth it to me and my use for the car (local cruises and a couple of longer drives to area car events with about 100 mile radius of my home.).
COMMENTS? SUGGESTIONS?
THX-TeeScott
A big part of the value of your car is that it’s a original 340 car (even a 73). A 360 engine is a downgrade, in my lowly opinion.
If it were me, I would just rebuild the 340 with some internal upgrades like lighter pistons, roller rockers, etc. If the heads are cracked, keep them in storage, but go with aluminum heads.. same cost, or cheaper than fixing old heads; plus you already have the manifolds, brackets, etc.
I built a 408 stroker. It was a beast, but it got about 10 mpg, and I had to run premium gas. So that may be a a negative consideration.
And a Magnum engine is balanced differently than an LA 360, so either neutral converter and magnum flexplate, or neutral flexplate & magnum converter. Also, are you running a/c? You may have a tough time mounting the original compressor on the magnum. You can run a magnum compressor on an Edelbrock 7577 intake, with the magnum serpentine set up… but you will need custom hoses. I’m sure there are a couple other magnum mods I’m forgetting.
I agree with Adam, keep it original! A numbers matching 340 car is worth a lot more than one with a 360. Since you have a running driving 340, there not too much wrong with it that a decent rebuild with higher compression pistons wouldn't fix. Plus you can get a stoker kit for the 340 for around $2600, machine work for your block and heads around $2500 (easily) and you'd have a numbers matching beast of a 340/416 small block!
As for you question, cubic inches cost more money the bigger you go. Both ATK and Bluepoint build decent crate engines.
In case you don’t rebuild your 340, contact Johnny Mac at Blueprint engines. he’s a sponsor at FBBO and a vendor at FABO.
I would do a compression and leak down test, then you know the condition. Yeah or Nay. I have done this before with a 4 cylinder in the in truck. Pulled the head and honed the cylinders slapped rings and bearing in. Change timing chain, lapped valves, change valve seals. Cheap refresh, buys time and save money.
If Main or cranks seal leaking. Sneaky Pete ( That can be done in the car) to change rear main seal. As above do tests. Pull motor and just clean up change rear seal and crank seal. Pull valve covers and put air to cylinders and change valve seals. do timing chain.
The advice above is good. But when you break the engine down. Today you are into BIG money. It's like buying a house you are never done. Just have deep pockets. I just want to say 10K. Not to mention the time it takes to get it done. Not your time, the mechanic and machine shop and getting the parts. To many factors.
That's why I say test. Then see which way to go.
IMO, there is no loss in value if the original 340 is retained, even if it isn't installed. If a sale is in the future, then you offer it with the car in addition to the 360, that's a net benefit.
For your use, the 408 doesn't seem to be worth the extra bucks, especailly if you are paying to have all the work done.
I bought a new ATK 408 Stroker with the intent of installing in place of my 340. I purchased this specific engine because it was internally balanced like my 340, could use the same front harmonic balancer and torque converter, and allowed for minimal changes to my drivetrain along with the ability to use the external LA parts. Was going to rebuild the 340 in the interim while having a workable and mobile Challenger. Nice engine, but I went with the rebuild of the original 340.
IMO for value and less work, have your original engine rebuilt. I sold the stroker a short while ago in November.
THX-TeeScott
Between the two reman companies, I would go with Blueprint without hesitation.
Having said that, you can probably get the current engine rebuilt and get a performance increase out of it for the same or less money. I recently had my 340 rebuilt by a gentleman in Concord, NC that has extensive experience with Mopar engines. I delivered the stock stroke short block with new aluminum heads and a used solid lifter cam. He did all the machine work including decking, bored/honed with a torque plate, bushed the lifter bores, provided new lightweight rods and pistons, lightly ported the heads, and balanced everything and put it all together. Tons of attention to detail. It dynoed 465hp/433lb-ft with no tuning because of time limitations, and cost less than what Blueprint charges for the stripped 375hp stroker long block. If you are interested I can give you more information or get you his contact information. It was well worth the drive to drop off and pickup. He can do it wild or mild, whichever way you prefer, but it will be done well.
Both are reputable sources. I don't think you can go wrong with either one.
Keep in mind two things:
"A crate engine is someone else's idea of what you want." Kinda like a mail order bride...
Blueprint's "warrenty" requires you to remove the engine and send it back. You pay to R&R it, they pay freight.
The last (but not only) Blueprint story I heard, a customers son in law reported 7 weeks to get his engine back for "water in the oil" (about a quart) after around a 15 mile test ride.
He not only paid for the R&R, but for storage at the shop.
Your results may vary.
TIMINATOR
Here's a scenario to rebuild the numbers matching 340. Say you buy a 360 crate engine and install it and get the car running great. You stash the original 340 over in the corner to help keep the value of the car later. All is golden. The something tragic happens, like the Maker calls you home or less tragic, you have to move suddenly (flood, fire etc.). In both cases the engine could be forgotten or misplaced (hey sugar honey iced tea happens). Now you have a Cuda that no longer has its original engine. Value is down. And that really sucks for not only you or your family, but the whole hobby as a whole. I would bet our Mopars (percentage wise) have more matching numbers vehicles than any other car make.
TIMINATOR
Any shop can have a problem with a new engine even with taking meticulous care. If there is a local shop that has a great reputation that is current, then that could be a real plus. Many shops had a great reputation but the skilled guys are getting older, retiring, etc. and those taking their place are not so much so. I've put two 408 strokers from Blueprint Engines into my 1970 Dusters and they've worked just great. Both engines dyno'd at over their advertised HP & TQ.
In my case, having a drop in engine was preferable to a local build. I had a 440 block that I bought a 512 stroker kit from 440 Source for the local shop to build for me. I would not do a local build again.
The Finer Details was the shop that assembled and finished my 70 Challenger. Justin is a very good engine builder - I would trust him to rebuild your engine, and sleep just fine at night. Kevin is a top notch in the paint department - my car came out perfect. Allie tracked down S.E. parts I couldn’t source…..
Your car is in excellent hands…..I’m sure you will be happy in the end.
Doug
