I'm thinking about replacing my 340 (1973) with a later model 360 Magnum. The engine is in a 70 Barracuda that originally had a 383. It was converted to a AAR clone. Will the accessories (alternator, power steering pump) bolt on without modifications? Or, will I have to replace the pulleys with the serpentine type pulleys and replace the mounting brackets? The engine on the Jegs website has a cam cover that has provisions for a mechanical fuel pump. I believe since the 340 in the car and the 360 are both externally balanced so I shouldn't have any problem bolting the 727 trans to the 360. Thanks
