17" Rims / Need Center Caps
Titan1969
Orange County, CA
Hi everyone, thx in advance for any tips. I have aftermarket 17" rims and looking for a company who makes a center cap to fit a rim that large. I messaged Stockton Wheels awaiting a reply.
if it's simply a 17-inch version of the rallye wheel, I'm betting the same center cap is used.
I shouldve clarified im hoping to fit 60s style poverty caps. Stock axles, and stock offsets, just larger steel rim.
OK, what exactly are you looking for? The "Dog Dish" caps? There were two different sizes - 9" and 10" so you need to measure your wheels and see which size they are made for. Guessing yours look to be 9" but measure them for sure!!
I think you correct 9". I have never had hub caps on mopar steel rims, how do they attach to the rim? I tried searching online but pics only show front side.
See the three weird looking "tabs" around the inner circle just outside your lugnuts? They are shaped so the "dog dish" pops over them. They're pretty snug. usually need a pry bar (screw driver) to pop them back off.
ok yes I see them , just wasnt sure that would hold the hubcap. Ok Im going to order a set of 4 x late 60s poverty caps and Ill report back.
The other style of hubcap, that locks into the outer rim of the wheel, all the factory-looking ones will likely be too small to fit the 17-inch rim. But the dog-dish may fit that inner part, with the tabs, although it may appear obviously smallish looking on the 17-wheel.
Ordered 4 x Poverty Caps from Scottys Hubcaps and they fit perfect! I wanted a performance tire and rim, so the 17" Nittos and rims solved that. I did not want a flashy rim and wanted to keep the nostalgic look so the caps solve that for me.
