Ididit Relay Wiring
wiging19
North of Seattle
Below is a wiring diagram for Ididit I've been able to put together based on using my original plug into my console wiring harness. Could someone validate this is correct. I'm looking for validation of the question mark line in particular. I want to be sure I'm wiring correctly before I'm too far into the project. Thanks
That looks correct, to me. 14-brown is START, and 16-drak-blue is RUN.
do I combine those two on the Ididit wire side into the original plug. That is what we think is correct, but I don't want to harm my under-dash harness. I've been very careful about my wiring situation since I bought the car. Basically replacing all wiring in the car because of the experiences I've observed my father going thru in used cars he bought and worked on. If you don't hack things together you normally don't have wiring problems.
I don't think so. The brown wire goes directly to the engine compartment, so focus on the RUN wire, the dark blue one.
