Steve340
The pictures were not great but the drums seemed scored and have some weird marks.
I had an A body car with power brakes that I replaced the MC in. The pedal went almost to the floor before the brakes engaged. I pulled the master away from the booster and lengthened the pushrod. Worked great for a couple of days. As I was driving once after that and applied the brakes the brakes locked up tight. I shortened the rod a little and all was good. Think the master still had some air and the rod was just a bit too short. My experience anyway!Yikes, my 72 Challenger was tough to stop because it had manual brakes with self adjusters.
However, it did stop. The pedal was just high and hard with little feel compared to the regular power brake cars I usually drove.
I am going to bleed but first I am going to see what adjusting my power booster pushrod wil do. It is a brand new booster; I am not sure the shop did the adjustment when they put the MC on. I don't have the tool so I am going to figure out a way to measure the MC bore depth. I want to do this with the MC in the car. At least this will eliminate the possibility this is the issue.
Post a picture of the brake parts that are installed.Classic Industries, a rear brake adjustable proportioning valve,
If you go to post #4 in this thread, on page 1, I have provided photos already that may be helpful. Please let me know if you need additional photos. There are a couple of the metering valve and the Wilwood adjustable proportioning valve I had installed.Post a picture of the brake parts that are installed.
Thanks on this! I ordered a booster pushrod gauge because I want to try and get it right the first time and not have to take it apart again. What I am seeing online is necessity to make sure there is a .010 gap, and I have feeler guages for that. Hopefully I can just move the MC forward without screwing up the lines. If the MC is leaking, well that is another story. And of course the fluid could damage the rubber parts in the booster.I had an A body car with power brakes that I replaced the MC in. The pedal went almost to the floor before the brakes engaged. I pulled the master away from the booster and lengthened the pushrod. Worked great for a couple of days. As I was driving once after that and applied the brakes the brakes locked up tight. I shortened the rod a little and all was good. Think the master still had some air and the rod was just a bit too short. My experience anyway!
Challenger RTA, I see the valve stem is in the up position. Isn't this normal? From the FSM, pp 5-22 to 5-23, it looks like you only need to clamp the stem into the up position if doing pressure bleeding. For gravity and pedal bleeding, it does not look like this is necessary.A picture tells the story. This is more then likely your problem. Been there done that. If I had a dollar for every time that I bleed brakes. I wouldn't be here! Only had this problem one time.
Get the clip. Don't need it. Make sure it moves freely. Pull it up clip vice grip or other or just have someone hold it up when you bleed the brakes.
View attachment 156923View attachment 156924
