Window regulator bolts
I got some for the same job at Home Depot last Friday. The captive washers are on the originals. I had to use bolts and washers from Home Depot. The originals are easier to use.
Original bolts
No one but the person installing them or the next owner if you sell the car to them under the assumption it is all original and as mentioned much easier to use with the factory washer on it. Also with originals you won't have to worry about the hardware store China junk metal ones stretching over time and coming loose
Who's gonna see em ?
You must be one of those "numbers only" "all original" "purist" "elite E body guys" if your gonna tear a guys door panels off when buying or judging it !. I've been restoring cars for over 30 years and used regular hardware where needed. No Chinesium Junk around here. Are you a vendor of nuts and bolts perhaps?
Guys, this is about the OP looking for hardware for his built, not to sit and bash each other for using what hardware. Cool it.
