will it cause serious damage if not immediately repaired?
https://www.youtube.com/watch?v=-KJbCSgCt6g
noise travels, i would try to isolate it. maybe take one belt at a time off. if you still have this noise than it's not an accessory. i hate to say it but it could be internal engine noise. did this come on all of a sudden
I had a similar rattle in my 340 it had a sticking valve & damaged no 3 cam bearing it sounded like a rocker hitting the rocker cover really sounded external was towards the rear like near the middle of the inlet manifold went away once the engine warmed up mainly around 1500 to 2000 rpmwill it cause serious damage if not immediately repaired?
The other rattle i had trouble finding was a bolt on the flex plate hit the converter cover oncewill it cause serious damage if not immediately repaired?
each turn of the engine have you hit anything under the car & dented the torque converter cover.
