large Inventory of E body parts - motivated seller
I have a 1970 Dodge Challenger 340 that came with Air. I'm putting the air conditioning components back in. I need all the pullys for ac for this car. Do you have any of them. Also looking for a 70 alternator for ac for this car and some of the a/c lines that run up the passenger side of car from the condensor.
Thanks,
Mike
Looking for the left (Drivers side) splash shield that goes between the door and front fender on a 70 Cuda. If you can help me out let me know the cost with shipping and preferred payment to get it to me at zip 81403. thanks, 72*birdman
Looking for these parts, build date of my '70 Challenger is 12-1-69, engine build date is 11-11-69, would prefer numbers matching/numbers correct
thanks
  1. Dual-Point distributor – I think the correct part # is #2875982
  2. Fan Assembly – Fan part# 2863216, fan clutch part# 2806070
  3. Driver side remote mirror – part # 2999549
  4. All 4 wheels - steel, rallye style, 14x6 or 15x7, trim rings, caps
  5. Bumper jack assembly, spare tire assembly, spare tire/wheel
  6. Wheel lip moldings
KZ - Since numbers are important to you, try looking for the things you need here..... http://www.tonysparts.com/
I've bought 'B' and 'E' things from Tony several times and it's always been a good (but sometimes expensive) experiance dealing with him. :-)
Steve
Hi Joe,
I tried PMing you this morning but your INBOX is full....
Do you happen to have a decent original 'E' Body Transmission Mount (not the cross member) in your inventory? The Mount attaches to the tranny with 2 bolts and also attaches to the crossmember with 1 long bolt.
The Hemi Mounts came painted bright Yellow from the factory while the other engine sizes were black. I believe that the factory P/N was 2892471 and this would be stamped into the Mount.
Thanks!
Steve
Thanks,
Mike
I have boxes full of pulleys. I will need to know dimensions and other details to be able to help you. Joe
Hi Joe,
Thanks!
Steve
I have several of these mounts. I will check to see if I have any in good shape.
Wiring
Looking for 71 challenger dash harness, standard gauges, automatic, console
