FOUND WANTED: A833 Operating Levers 1-2, 3-4, Reverse
rklein71
Amarillo Texas
Need the operating levers that fasten on the side cover for my 71 Barracuda A833. I know they are available repro, hoping to get a set for cheaper.
Thanks,
Rod
Amarillo, TX
Just be careful, a cheaper set may get you a worn out set. Many times the slotted attachment area is wallowed out and you will have sloppy shift levers. Look over the used ones carefully.
Good point,
I can weld in some material and file them out if necessary. I am planning on doing heim joints on them, so modifications are already in planning.
Rod
