Hi guys, I have a bored .040" over 408 with the J head and air gap intake, ~10.25:1 compression. Just got the engine running about 2 weeks ago.
The engine runs absolutely perfectly, however I have been having smoke on deceleration out of the drivers side (right bank) cylinders. Engine compression is perfect in all bores. I replaced the valve seals, that didn't help. I have now deduced the problem to be the intake manifold not seated. As many of you know (and now I do too,) when you deck the block and heads, you need to either modify the head or the intake so they mate up.
My issue is, I don't know how much material to deck off the intake.
The engine block and heads are my dads and I don't have the information of how they were processed. I can tell you the block is decked to the point that the cylinder is about .001" off the deck. I am not sure how much that means the factory block has been decked. Also, I can tell you the "J" head is at 62cc, and at factory specs they were more like 68-72cc.
I'm hoping someone can tell me how much material has been decked?
Ie: (in order to have the cylinder on the deck, you need to remove "X") + (in order to have the J head at 62cc, you need to remove "Y"). X+Y = total amount decked.
Last but not least, I'm wondering if it's legal to just drill out the holes on the intake bigger so it can mate up with the heads. That would be easiest and cheapest, but I would prefer to do it right. I would prefer to not remove the heads if possible, I would like to race the car in a week and I think removing the heads and having them reworked would pretty much end the possibility of that happening.
Thanks in advance for any feedback!
