New Product - E-Body Dash Speaker Grilles
YEARONE
FEBO Vendor
FEBO Vendor
NEW PRODUCT... In stock and ready to ship. 1970-1974 E-Body dash speaker grilles for 3 speaker dash. Made In The USA.
https://www.yearone.com/Product/challenger-cuda/esgsnat#prettyPhoto
6PKRTSE
Figures, I just bought some used speaker grille covers for $50.00.
Larry4406, I believe it's completely different as the metal portion of the dash and obviously the das pad doesn't have the cut outs. But, if you had the measurements and were careful cutting the holes, the kit above should work and cover up the actual hole.
Katfish
Palm Bay, FL
I’ve never seen a dash pad (metal portion) without the holes. You’d need to cut the foam.
YEARONE
FEBO Vendor
FEBO Vendor
What exactly is involved in adding this to a dash that did not come with it?
the metal inner structure of the dash pad on some non 3 speaker dash pads are already cut out but most are not. The easiest way is to mount the metal reinforcements to the underside of the dash pad as they really only fit in one spot the way that the dash pad is made. Mark and carefully cut the metal structure out, then carefully cut the foam and vinyl out a little at a time until the speaker grille and speaker fit flush with the pad. We are working on templates and hopefully have that available soon.
YEARONE
FEBO Vendor
FEBO Vendor
Very nice! And not a horrible price considering what you're getting!
Thanks, We wanted to keep the price down as much as possible. With material costs changing constantly that is very difficult to do these days. Hopefully we will be able to maintain this cost for a while.
