Hey Kansas, that’s another tough part to find. Try Classic Industries type in part # RB2691201. This may have the cover you’re looking for included in the package. Regards Rob 🏝
Hate to be "that" guy, but I have to bump this to the top. Surfcuda had a great suggestion, but the listed belt isn't the "exact" factory type seat belt. I've scoured eBay and have found every component except the part I need. I've seen most episodes of Graveyard Carz and Mark gets some pretty nasty cars in. He states when he is done they are exactly like when they leave the factory. I assume this includes small components including seat belts.
Does anyone know the vendor he uses for reproduction seat belts?
you may be able to repair that belt sleeve using some large diameter heat shrink tubing. it often comes in black. place 8 inches of it over the cracked area, heat it and press it flat. or use a longer length if that looks better. while it may not be "show quality" I bet it will still look great and tolerate use (and abuse) through typical usage.
